qsfp to 4 sfp+ adapter (not breakout cable) in nexus 3064-T
Ali Hosny
Is there an adapter to convert one qsfp port to 4 sfp+ female , the problem is i have a nexus 3064-32T at the core , i would like to connect 3X 2960XR-24TD-I each with double 10G om3 fiber cables but the 3064 only has 4 uplink ports so even if i used the qsfp to sfp adapter i would then only have 4 ports while i need 6 , also 2 of the 2960XR are at 50M on another floor so i can't use the qsfp to 4 sfp+ breakout cable. any recommendation on how to acheive this setup even if i have to change my core switch knowing that i need the core switch to have 10G base-T ports since all my servers and storage are 10G base-T.
Thanks in advance
Leo Laohoo
Whoops!  Response deleted.  Didn't realize you're looking for something beyond 5 m.  I guess "QSFP-4X10G-AOC" is not valid either.
