07-15-2013 04:58 AM - edited 03-07-2019 02:24 PM
I think policing or shapping applies to the entire traffic going through the port.
How can i limit the speed per connection for instance
have 3 mb of overall available bandwidth with each client being able to take up 500kbps and if available all.
in this can what happens when the line is overloaded and client connection can not be guranteed to have 500kbps(50 connections each trying to download 500kbps at the same time on 6mbps) , does it go back to best effort delivery ?
many thanks
07-15-2013 07:45 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, usually shaping or policing applies to aggregate flows.
An exception is microflow policing, available on 6500. With that you can police individual flows.
In an example cases like you describe, where multiple flow aggregate bandwidth demand exceed available bandwidth, individual flows will compete for the bandwidth, and yes, that often would be considered "best effort".
Not withstanding the above, instead of worrying about policing individual users to some set amount of bandwidth, you might instead consider managing possible congestion by either allowing proportional sharing (a fair-queue approach) or by some kind of different service treatment based on the kind of traffic (e.g. real-time and/or interactive traffic gets priority to bandwidth over bulk data transfers).
07-16-2013 05:18 AM
thank for the reply and clarifying that only aggregate flows are policed and shapped on cisco device, at least not unless you get a top of the range device.
I am trying to configure this on asa 5505 and asa 5515x , I think they only have standard and priority queue and no option for WRED Red etc but just low latency queue , am i correct ?
basically what I am trying to avoid is one person hugging all of the available bandwidth and slow everyone else down for that specific protocol
07-16-2013 08:23 AM
Disclaimer
Posting
Sorry, I'm unfamiliar with ASA QoS capabilities.
