queing methods
carl_townshend
Hi all, with queing in switches, how doe they work, I know by default it is FIFO, so does FIFO work on a per frame basis or per flow ? if it was per flow I guess there would be big queues ?
also how does WFQ work?
who decides the queing mechanism on the switch, and do they really make that much difference ?
tomek0001
Level 4
Level 4
It is hard to answer all of these questions because of the depth of information there.
I would recommend this book http://www.amazon.com/End-to-End-QoS-Network-Design/dp/B0014YHKRC?&camp=212361&linkCode=wey&tag=cs02c-20&creative=380733
..which talks about qos in greater detail.
/please rate if helpful
Thank you
Tom
