query regarding enabling cisco SNMP..
helo all,
i have an orion npm that is connected to my network.. and i want that all of my devices will send snpm to the orion npm.. will i need to configure the switches and router for SNMP Support? will i need to hardcode in the switches and router the snmp commands?? thanks
johnlloyd_13
Level 9
Level 9
hi,
you'll need the SNMP community string configured on your devices.
advisable to use read-only access and tag an ACL.
(config)#snmp-server community
hi johnlloyd,
what will i put in the int the portion? can you give me an example? or does the one you code above is already the one hardcoded in the cli?
thanks
hi,
the string is like a password. both the IOS device and NMS (orion) must use the same string.
a sample would be as below:
Router(config)#snmp-server community mystring ro
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other posters have noted, you define a SNMP community to allow SNMP queries against your host.  Besides the community value, which acts as a password, you might want to define an ACL to limit what other hosts may query your host.
Also, you may be able to configure your Cisco device to SNMP trap (or inform) another host when certain events happen.
