question about AAA from router not from radius ??
Dr.X
Level 2
Level 2
hi ,
im using  L2TP tunnel between LAC Router and LNS router
LAC===============LNS===========>internet
customers uses pppoe and type the username xxx@lns1
i have database server and radius server ,
my request is ,
i want to make a test account and put username and password on router not on radius and databse
my question is wt i need to config on router ????
i want just to put on customer adsl router the username test@lns1 nas password 123 , wt i need to autenticate this username from router not from AAA radius ???????
i will paste my current config on router that AAA from radius server , and  want to know what i need to do if i want the AAA from router itself
here  is my config  on LNS router :
aaa new-model
aaa group server radius radiusservers
server-private x.x.x.x auth-port 111 acct-port 111 key 7 1ccccccccccc
aaa authentication login adminstaff local
aaa authentication login sdm_vpn_xauth_ml_1 group radius
aaa authentication ppp vpdn group radiusservers local
aaa authorization network default group radius local
aaa authorization network vpdn group radiusservers local
aaa authorization network sdm_vpn_group_ml_1 local
aaa accounting delay-start
aaa accounting update newinfo periodic 5
aaa accounting network vpdn
action-type start-stop
broadcast
group radiusservers
aaa server radius dynamic-author
client x.x.x.x server-key 7 34wefwefwefwefwe
interface Virtual-Template1
ip unnumbered GigabitEthernet0/1
ip tcp adjust-mss 1412
no logging event link-status
peer default ip address pool 111
ppp mtu adaptive
ppp authentication pap vpdn
ppp authorization vpdn
ppp accounting vpdn
ip radius source-interface GigabitEthernet0/1
logging alarm informational
radius-server attribute nas-port format d
radius-server configure-nas
radius-server host x.x.x.x1 auth-port 111 acct-port 111 key 7 fgsgsdgsdgsdgsdgsd
radius-server retransmit 0
radius-server key 7934t788uf2
radius-server vsa send cisco-nas-port
radius-server vsa send accounting
radius-server vsa send authentication
9 Replies 9
Giuseppe Larosa
Hello Ahmed,
the AAA ppp authentication list of methods that you have is:
you need to change this in
aaa authentication ppp vpdn local group radiusservers
because the order of authentication methods is important with the current  version of the command the radius server is contacted first, and local is used only if the radius server is not reachable or it does not provide an answer.
Edit:
you will likely need to change also the aaa authorization network list  of methods in the same way.
Hope to help
Giuseppe
hi
Giuseppe ,
thanks for your reply ,
i have a question ,
can i edit the config , and 1st to see the  local router database , and if no answer from router or not found on router local database , then=============> go to radius ???
can i  do that ??
if yes , wt config shoud be modified ??
regards
Hello Ahmed,
the configuration change that I have suggested in my first post in this thread should do what you want: look for local database first and then go to radius
the order of the list of authentication methods is local first then radius with this command
Hope to help
Giuseppe
hi ,
i changed one command as you  request , but couldnet  get authenticated by local router database !!!
shoudl i change the authorization and accounting ??
i
regards
another questions
have look at the command
my question is , wt about the adminstaff location ???
it is not in router config ???!!!
regards
Hello Ahmed,
you should try to change also the list of authorizzation methods
However, in an L2TP extended PPP sessions scenario, the use of RADIUS may be mandatory. It is not so easy to work without the Radius. As a workaround you could create a test user account on RADIUS server.
This would allow to test all the chain,
this is a list of authentication methods to be used for login, if used in router configuration expect to see it under line vty or line con 0 configuration stanzas.
To be noted a list of authentication methods can be defined and never used this is not a problem.
Hope to help
Giuseppe
hi
Giuseppe ,
about the radius authentications ,
yesterday , the config commands was written , and the radisu server wasnt ready yet , and i could login using local databse using the previous commands i posted in the 1st post .
but after radisu server has been up and configured , i no longer can user local database from router ,
i will try to change authorization and give u a reply
about the
adminstaff list , im not understanding wt is this list  !!!! is this a list that contiains info , or it is just a name ??
and when the info of this list ?
regards
Hello Ahmed,
1)  authentication ppp
When the RADIUS server is offine or it does not answer the list of authentication methods moves to the next method that is local in the original list.
Once the RADIUS server is up and running it will answer to AAA authentication requests made by the router using RADIUS messages. This is the reason why a locally defined username/pwd pair does not work anymore the RADIUS server replies with a FAIL message.
The router does not move to next authentication method so the ppp authentication fails if the user/pwd is only locally defined
2) adminstuff
AAA can be used to provide lists of methods for different operations the aaa authentication login specifies a list of authentication methods to be used for accessing the device on vty   ( telnet or ssh sessions) or on console
so the
aaa authentication login adminstuff local
line vty 0 4
login authentication adminstuff
is equivalent to:
no aaa new-model
line vty 0 4
login local
see
http://www.cisco.com/en/US/docs/ios-xml/ios/security/a1/sec-cr-a1.html#GUID-3DB1CC8A-4A98-400B-A906-C42F265C7EA2
Hope to help
Giuseppe
hi ,
Giuseppe
i could finally edit the authorizatin command and arranged it like the authorization command , and i could now check  the local then radisus server
thanks
regards
