question about ICMP and DCHP
levijj0909
What are the differences between DCHP and the ICMP messages that were previously used for startup configuration? What are their strenghs?
Thx!
Ganesh Hariharan
Thx!
Hi ,
DHCP protocol is utilized by some network nodes to automatically retrieve their network configurations from a centralized server and icmp is a complementary protocol to IP (Internet Protocol). Like IP, ICMP resides on the Network Layer of the OSI Model.ICMP is designed for sending control and test messages across IP networks.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
hi.
what is DCHP ? may be DHCP ?
dhcp is dynamic host configuration protocol, using for assign ip , dns, gateway, and other options for network device.
icmp is protocol, which using for example ping (icmp type echo and echo reply). other word for test connectivity between network device.
Ganesh Hariharan
Thx!
Hi ,
Hope to Help !!
Ganesh.H
