10-14-2012 11:54 AM - edited 03-07-2019 09:27 AM
hi ,
i want to ask about estimating the leases duration from router when artributes of IP are given to router from radius .
assume the AAA is from radius server , and im jusing virtual template interface that gives the users an ips .
now assume if from radusi we gave the user x an attribute :
ip:addr-pool=pool1
note that the user x will have an ip from router <pool1 >
but im facing a problem which is , if the user get an ip z.z.z.z from pool1 , and disconnected , then connected and so on , it will always get the same ip which is z.z.z.z
my problem in another way , if i gave a user an attribute to get its ip from router pool , it will seems as im giving that user a fixed ip !!!!!!!
my request is , how to solve this issue and how to define a leased duration to the users when they get an ips from router pools .
i will paste simple config which has relatinion to my question
interface Virtual-Template1
ip unnumbered Loopback1
ip tcp adjust-mss 1412
no logging event link-status
ipv6 unnumbered Loopback2
no ipv6 nd ra suppress
peer default ip address pool pool1
ppp authentication pap vpdn
ppp authorization vpdn
ppp accounting vpdn
ip local pool pool1 x.x.18.0 x.x.19.254
radius-server attribute nas-port format d
radius-server configure-nas
radius-server host x.x.x.x auth-port 1812 acct-port 1813 key 7 xxxxxxxxxxxxxx
radius-server retransmit 0
radius-server key 7 xxxxxxxxxxxxxxxxxxxxxx
radius-server vsa send cisco-nas-port
radius-server vsa send accounting
radius-server vsa send authentication
whish to help
regards
Ahmad
10-16-2012 10:33 AM
