question about MLS and its operation
Dr.X
Level 2
Level 2
hi  ,
im trying to understand the MLS operation .
uptill now i understood that the MLS will work as a router if the port of the MLS configured as a router , and thwe MLS will work as switch if the port of the MLS configured as a switch .
this is a confusion i want to know  about .
my queston is ,  does the opearation of the MLS depend on the port configured or depend on another things ???
regrards
Raju Sekharan
The MLS operation depends on the way you have configured the port
1. If the port is configured with  no switchport", it will do only routing. It will not do any switching
2. if the port is configured as part of VLAN and there is no " interface VLAN" configured for that VLAN, it will do only Layer2 switching of packets
3. if the port is configured as part of an Access VLAN and you have routing enabled on that VLAN, it  can do switching and routing for the packets received on that port.
Raju
14 Replies 14
Reza Sharifi
Multi-Layer Switching (MLS) is part of the function of the switch.  Traditionally, most switches had layer-2 capabilities only.  MLS provide layer-2 and layer-3 functionality on the same device.  It used to be that only bigger switches like the 6500 series were capable of MLS, but now days most small switches i.e.. 3550, 3560, 3750, etc are capable of doing both.Of course, there are still some switches that can do layer-2 only.
Raju Sekharan
Raju
rajs2 wrote:
Raju
hi
Raju
thanks for ur reply ,
i think i was right when i said that the mls operation depend on the port config , but agian
the point 1 and 2 i understood them .
but the point 3 not yet !
can u give me explanation  or the sequence that will happen when packect reach a port configured for access and its vlan interface has an ip .
regards
1. The packet goes through layer2 lookup first. This is based on the destination MAC address. If the destination MAC is of the router's own MAC-address it will forward the packet to next layer for L3 lookup. if the destination MAC is belonging to any protocols. like CDP, STP,BGP,OSPF, those packets will be forwarded to the CPU. If the destination MAC is learned from some other port on same VLAN, it will be forwarded to that port. if the destination is not present in CAM table, packet will be flooded on all the ports belonging to that VLAN
2. During L3lookup, it will look at the destination IP address and forward the packet to the right port after adding the layer2 Encapsulation
Raju
rajs2 wrote:
1. T If the destination MAC is of the router's own MAC-address it will forward the packet to next layer for L3 lookup.
Raju
about u said above ,
what do u mean with
do u mean in this case the vlan mac address of the port that is access port and its vlan has an ip  , or  another thing ???
- Access port doesnt need any MAC address to be assigned. Normally, on L3 port (physical or SVI) will have MAC address and if receive any frame with destination address as self MAC address (any MAC address assigned in local interface).
By, Router's MAC address, Raju meant the Layer2 address assigned in any L3 port of the router/switch.
HTH,
Nagendra
hi
Nagendra
lets have an example :
assume i have MLS with vlan 1 & vlan 2
each vlan  svi interface has an ip and has routing enabled
                                               L2  -Switch 2960
                                                         Gi1/4
pc1 vlan 1--------------- Gi1/1---MLS-----Gi1/3-------------------router
                                                        Gi1/2
                                                   pc2 vlan 2
as u see now , Gi/1/1 & Gi1/2 are configure switch ports and acces ports to vlan 1 & vlan 2
Gi1/4 is connected to L2 switch  and working as L2 with trunk port
Gi1/3 is connected to Router and working as L3 port
vlan 1 ip is 192.168.1.1/24
pc1 ip is 192.168.1.2/24 and its ip gateway is 192.168.1.1
vlan 2 ip is 192.168.2.1
pc2 ip os 192.168.2.2 and its gateway ip is 192.168.2.1
now when pc1 want to talk to pc2 i think that pc1 will send to the default gateway which is 192.168.1.1 and  send arp and get the mac of the vlan routed interface and in this case the MLS will look in the routing table ????
is my info correct ???
Look at my below config
interface TenGigabitEthernet10/1
ip address 192.168.12.1 255.255.255.0
7600-1#sh int ten10/1
TenGigabitEthernet10/1 is up, line protocol is up (connected)
  Hardware is X40G 10Gb 802.3, address is d0d0.fda5.6400 (bia d0d0.fda5.6400)
You can see the mac-address d0d0.fda5.6400 . If this router receives packets with destination mac-address d0d0.fda5.6400 , it will forward the packet to layer 3 for layer 3 processing
Raju
Raju
so , u mean that if a packed recived has destination mac of L3 interface if it was a svi or physical interface ,  am i right ??
Yes. Any L3 interface (physical or SVI) will obviously have a L2 address. If a pure L3 interface receives a non self MAC address, it will ignore the packet. But if an access port (which is also enabled with SVI) receive a self destinated MAC address (address of SVI), it will decap and further look inot the L3 header. If it receives a non-sefl MAC address, it will treat it as L2 packet and behave as a normal L2 switch.
-Nagendra
Yes. if the received MAC-addres is of the routers L3 interface, the packet is handed over to L3 for routing the packet
Raju
hi
Raju &
-Nagendra
thank you very much ,
in summary , i can say that MLS has 3 cases that control it how to operate  as raju said :
uptill now  i feel i got good explanation about MLS operation , im wondering why the ccnp books didnt mention the point 3 above ???!!!!!
i read all the ccnp switching book and didnt have a good expalnation of the MLS ,
any way , thanks both for ur info u posted here .
any new question go in my mind i will ask it here
regards
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
CSCO12006413 wrote:
hi  ,
regrards
MLS is basically L2 like switching of L3 packets.  It depends on both the capabilities of the hardware and that you're doing L3 forwarding.
Newer L3 switches hide the details of MLS, i.e. they do it auto-magically, but if you research, on Cisco's main web site, MLS on 5500s, especially using an external router, it may help clarify what MLS is all about.
MLS switches comprises of layer 2,3 and 4 to make it MLS there are some MLS switches that have there port enabled as a layer 2 so all you need to do is to check with the command show int fa0/1 switchport that will tell you what layer the switch belongs to.
and for your question if you use the no switchport comman on an interface it means you are hardcoding the port to work as a layer 3 switch and if u use the switchport command it will only work on layer mode. and routing is only performed on layer 3 mode for intervlan communication.
