Question about network design?
wael azzam
Level 2
Level 2
Hello all ,
I need to know why the link between the two core switches when design a network ?
And also  what can I do to understand the functions and configuration of links between core,distribution and access switches.
thanks
5 Replies 5
devils_advocate
Level 11
Level 11
Perhaps it might be an idea to read up on the CCNA/CCNP material, not being rude, just making a suggestion
Are you asking why there is a need to connect core switches together?
Simon Hill
There are lots of reasons. For example, what would happen if connectivity to the distribution switch/s has failed? Without a link between the core switches, the traffic has no where else to go.
Ji-Won Park
Level 5
Level 5
Hi, wael azzam
You need to have a loop for redundancy in your network and spanning-tree protocol is there to block the certain interfaces to kill the loop. There are many different ways to design a network but what you're referring to is a well known layer-2 looped topology. However, since there are many new technologies out there, you don't need to rely on spanning-tree anymore. I like to design the network with VSS or vPC.. makes my life easier.
Study 642-874 ARCH, this course will help you understand many different design scenarios.
Thanks.
Ji
Thanks jiwonpark for your help ,
I will take your advice and  read about VSS and VPC .Also study 642-874 ARCH
Thanks again
wael azzam
Level 2
Level 2
Thanks all for information
