question about null 0 static route
Dr.X
Level 7
Level 7
hi ,
if i type
ip route 1.1.1.1  255.255.255.0 2.2.2.2
ip route 1.1.1.1  255.255.255.0 null0
ip route 0.0.0.0 0.0.0.0 9.9.9.9
if i typed the same route with two netxt hop ,
one to null0 and the other to next hop ip
Q1
what is the behaviuor of router ??
i mean  what is the sequency the router will look in this mannaer ???
will  the packet to 1.1.1.1/24  droped , or it will be forwarded to 2.2.2.2 ?
Q2
if i removed the route
and still typing
what is the behaviuor of the router ???
regards
AHmad
John Blakley
Ahmad,
Q1:
Because they're equal cost routes, they both get put into the routing table. The test that I did received one response and lost one response proving that it was losing traffic by also hitting the null0 interface:
Routing entry for 32.32.32.0/24
  Known via "static", distance 1, metric 0 (connected)
  Routing Descriptor Blocks:
  * 10.10.35.3
      Route metric is 0, traffic share count is 1
    directly connected, via Null0
R5#ping 32.32.32.32
Sending 5, 100-byte ICMP Echos to 32.32.32.32, timeout is 2 seconds:
Success rate is 60 percent (3/5), round-trip min/avg/max = 20/28/36 ms
R5#
S       32.32.32.0 [1/0] via 10.10.35.3
                   is directly connected, Null0
Q2:
This one will fall under the longest match rule. If you have a host going to 1.1.1.1 it will hit the null0 route, everything else would hit the default route.
HTH,
John
HTH, John *** Please rate all useful posts ***
