Question: How to wire two 2960 switch base on a config file?
davidnghk
The story,
the network engineer resign, I am the new guy with normal home network knowledge, as I am not applying the network engineer position, but somehow I got his task: replacing the switch.
the site contain the network equipment can only visit once per month.
I have not yet visit the site, and the last network engineer did not left any "network diagram", and I hear the wiring to both switch already disconnected, so I have no idea the wiring to the switch.
Need help on figure out the network diagram.
the only thing I know, hear from the guard that was watching the last network engineer work:
1. two switch in that site, I hear it is for redundancy, one of them broken, one of them is good, and the good one is in my hand, and I have access to its config.
2. the two switch model are WS-C2960-8TC-S, I hear they have different IP.
3 there is two firewall, I don't know the model.
4. might be two ISP cable connect to the internet, or might be just one, not sure.
5. one server, I assume it has two NIC port.
6. I hear the "SFP Modules" in the switch might be used.
7. the config of the good switch
Switch1#sh run
version 12.2
no service pad
hostname Switch1
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
crypto pki trustpoint TP-self-signed-33333333
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-33333333
 revocation-check none
 rsakeypair TP-self-signed-33333333
crypto pki certificate chain TP-self-signed-3333333
 certificate self-signed 01
  xxxxx
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
 switchport access vlan 35
 switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan11
 no ip address
 no ip route-cache
interface Vlan35
 ip address 192.168.0.61 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.0.148
ip http server
ip http secure-server
control-plane
line con 0
 password xxxxx
 login
line vty 0 4
 password xxxxx
 login
line vty 5 15
 login
end
davidnghk
got this disconnected photo from the guard
seems simple, right? for each switch
  • fiber cable to SFP in the switch
  • RJ45 to port 0 or port 7
so the purpose of the switch is convert the fiber signal to RJ45?
there is no fail over ? or am I missing something?
as per the information switch action as Layer 2 switch, but the failed switch is part of stack may be ?
can you check from working switch, show switch ( post output here)
we are also same like your guess, based on the cables ?
where is this yellow cable going ? to other switch ? what port they connected ?
BB
I already show the working switch config in my first post.
the yellow cable is the fiber cable, I guess it is to the switch.
Pay more attention what we asked for  - show switch ( post output here)
The yellow cable is the fiber cable, I guess it is to the switch.  - if you sure please carry on test it..what are you waiting for ?
BB
