question in asa default rule that say "any less secure network"
Dr.X
Level 2
Level 2
hi all ,
i want to ask ,
im trying to find the object that is called "any less secure networks " in the asa but i cant !!!
i can only set the "any" object !!
what i want is ,
i want to reset the asa rules to default , i mean that i want allow only traffic from high level to any lower level and block the other traffic !!
but  i can put only "any" rule , i cant see "any less secure network"
does that mean that it is mean " any less secure network "
 i have asa 5505 with ios 8.4
regards
Richard Burts
It sounds like you are attempting to write an access list to restrict traffic that implements the default rules. But the default is that there are not user created access lists. If you remove your access list then the ASA will enforce the default rule to permit traffic from a more secure network to a less secure network.
Rick
Rick
hi
thanks alot for reply ,
i mean that ias supposed to see rules like
http://www3.0zz0.com/2014/03/09/18/869485388.png
but i cant choose the object "less than"
does that mean if i deleted all the rules in the firewall , that these rules in the image above is allready applied ?
regards
