Question on ENTERPRISE SERVICES UPGRADE SSH firmware for a 4900M Switch
kbyrd
Level 2
Level 2
I have a few 4900M switches that I would like to upgrade. When I go to CCO, I see several versions of the Enterprise Firmware (151-2.SG8):ENTERPRISE SERVICES SSHENTERPRISE SERVICES UPGRADE SSHI'm currently running ENTERPRISE SERVICES W/O CRYPTO and want to run SSH.What is the difference between the two firmware packages above? The release notes do not discuss.Thanks in advance.
Mark Malone
you need to pick the image that has the K9 in it for ssh services like below , k9 will give you encryption , ssh etc
asr1001x-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
cat4500-entservicesk9-mz.150-2.SG11.bin
hzanzi
Did you ever find the answer to the difference between Enterprise Services SSH and Enterprise Services Upgrade SSH?
