09-29-2016 01:51 PM - edited 03-08-2019 07:38 AM
Which statement about routing protocols is true?
A. Link-state routing protocols choose a path by the number of hops to the destination.
B. OSPF is a link-state routing protocol.
C. Distance-vector routing protocols use the Shortest Path First algorithm.
D. IS-IS is a distance-vector routing protocol.
Under which circumstance should a network administrator implement one-way NAT?
A. |
when the network must route UDP traffic |
B. |
when traffic that originates outside the network must be routed to internal hosts |
C. |
when traffic that originates inside the network must be routed to internal hosts |
D. |
when the network has few public IP addresses and many private IP addresses require outside access |
Solved! Go to Solution.
09-29-2016 11:40 PM
quiz time ? Answer B is correct: OSPF is link-state routing protocol.
IS-IS is,too, by the way.
09-29-2016 11:40 PM
09-30-2016 12:54 PM
Ditto for first question.
For second question, I would say the correct answer is D. (Also NAT overloading, or PAT, would also be a solution for "D".)
