"Command Rejected port te1/1/1 is in over subscription mode.--- VSS Link issue
Asim Afzal
I have 2 cisco 6509 chassis .I need to make 40 gig Vslink between them .
--- show module switch factoryid ---
SW Mod Factory Identification
1 1 WS-X6816-10G-2T
1 2 N/A
1 5 VS-S2T-10G
2 1 WS-X6816-10G-2T
2 2 N/A
2 5 VS-S2T-10G
I have take two 10 gig interface from supervisor ten 1/5/1 and ten 1/5/2 and 2 interfaces from x6816 line card(port ten 1/1/1 and ten 1/1/2.When i add line card 10 gig interfaces to port channel 1 .I am getting error
I  have add a small diagram for better understanding.I need to make 40 gig vslink so kindly let me know how i will add other two interface line card WS-X6816-10G-2T
chrihussey
By default the ports are in 4:1 over subscription mode.You can turn it off for the entire blade in which only ports 1,5,9 and 13 can be used, or for a single port group.
For the entire blade the command is:
no hw-module switch (#) slot (#) oversubscription
For a group:
"no hw-module switch (#) slot (#) oversubscription port-group (#)
Below is a link to the supporting documentation:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-4SY/config_guide/sup6T/15_3_sy_swcg_6T.pdf
chrihussey
For a group:
Can i use one port from one port-group and other port from another port in same port channel
ten 1/1/1
channel-group 1
ten 1/1/5
channel group 1
That shouldn't be an issue.
