07-08-2013 01:52 PM - edited 03-07-2019 02:17 PM
I have three very large object groups that I'm trying to deny in an access-list. If I create the object groups and then attempt to deny them in an ACL I get a "% Duplicate ACE present after expansion.Aborting ACE addition!" error. However, if I create the object groups with just the first couple objects in each group, deny the groups in the ACL and then finish building the object groups I do not get a duplicate error. Am I correct in understanding the error as saying that there is a duplicated network between the groups? If so, why do I not see them when adding the networks to the object groups after they are already applied to the ACL?
Solved! Go to Solution.
07-08-2013 05:25 PM
Nathan,
CSCto56118 | Symptom: A duplicate ACE can be introduced in an ACL if the duplicate entry is added via an object-group. The parser will not detect/reject this dplicate ACE configuration. When the 6500 is reloaded and the ACL gets configured again during bootup, the duplicate ACE does get detected as expected. This can lead to a different access-list behavior before and after the reload of the 6500. Conditions: Platform: 6500 Software: 12.2(33)SXI Example: # Configure object-group Cat6500(config)#object-group ip address GRPTEST Cat6500(config-ipaddr-ogroup)# host-info 10.10.10.10 # Configure an ACL that uses this object-group Cat6500(config)#ip access-list extended GRPTEST Cat6500(config-ext-nacl)# permit tcp host 10.11.11.11 host 10.12.12.12 eq 22 Cat6500(config-ext-nacl)# permit tcp addrgroup GRPTEST host 10.12.12.12 eq 22 # Update the object-group with an entry which already exists in the ACL # This config change to the object-group is accepted (should not) Cat6500(config)#object-group ip address GRPTEST Cat6500(config-ipaddr-ogroup)# host-info 10.11.11.11 Cat6500#show access-lists GRPTEST Extended IP access list GRPTEST 10 permit tcp host 10.11.11.11 host 10.12.12.12 eq 22 20 permit tcp addrgroup GRPTEST host 10.12.12.12 eq 22 # When reconfiguring the same ACL again, the duplicate ACE does get detected # The config is not accepted as expected dr1.sto1.int(config)#no ip access-list extended GRPTEST dr1.sto1.int(config)#ip access-list extended GRPTEST dr1.sto1.int(config-ext-nacl)# permit tcp host 10.11.11.11 host 10.12.12.12 eq 22 dr1.sto1.int(config-ext-nacl)# permit tcp addrgroup GRPTEST host 10.12.12.12 eq 22 % Duplicate ACE present after expansion.Aborting ACE addition! Workaround: Check your ACLs to make sure you are not adding duplicate entries via an object-group |
Inayath
*Plz rate all the usefull posts.
07-08-2013 05:25 PM
Nathan,
Inayath
07-09-2013 05:11 AM
Right on InayathUlla!
Nate
