11-30-2008 02:20 AM - edited 03-06-2019 02:44 AM
I've a router with LAN address configured on Eth0. I have to attach a system to aux port and have to monitor the aux port when the port is down..I want monitor the port with the ping utility...I want to assign to aux port an IP address, with routing enabled..
How is possible that?
Thank you for your support.
Best regards.
Massimiliano.
11-30-2008 11:24 AM
Hello Massimiliano,
I was able to connect two routers in back to back using AUX ports.
see
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080093c7b.shtml
Hope to help
Giuseppe
12-01-2008 12:13 AM
Thank you Giuseppe.
I've already found that configuration example.
Best regards.
Massimiliano.
12-01-2008 12:41 AM
Hello Massimiliano,
the document provides the configuration on the router side.
You need to find the right cable setup to make it working if the other side in your case is a different device.
Hope to help
Giuseppe
12-01-2008 12:58 AM
Thank you Giuseppe.
Massimiliano.
