"Show interface VLAN" and Multicast Traffic
aletat0ne
Hi Gents,
I hope someone of you could help me.
I have 2 VLANs in my network rightly configured with pim (sparse-dence-mode).
In this 2 VLANs there is lot of multicast traffic and the multicast routing between vlans is working properly.
But when i type "show interface VLAN" I get some very strange value of traffic...
For instance:
Multicast Source in VLAN 10 (25megabits of traffic)
Receiver in VLAN 20
If I do "show interface vlan 10" I get the follow:
6506E-CS1-CORE#sh int vlan 10
Vlan10 is up, line protocol is up
  Hardware is EtherSVI, address is
  Internet address is
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 6/255
  Keepalive not supported
  Last input 00:00:01, output 00:00:02, output hang never
  Input queue: 0/75/19/19 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 25028000 bits/sec, 2291 packets/sec
  L2 Switched: ucast: 1036 pkt, 69072 bytes - mcast: 679269098 pkt, 906330264325 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 5960221256 pkt, 8127597456186 bytes mcast
  L3 out Switched: ucast: 9729 pkt, 2535765 bytes mcast: 8690750333 pkt, 11857610863658 bytes
     6258337235 packets input, 8529846060405 bytes, 0 no buffer
6506E-CS1-CORE#sh int vlan 20
Vlan20 is up, line protocol is up
  Internet address is
     reliability 255/255, txload 1/255, rxload 10/255
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/12568301/12351485 (size/max/drops/flushes); Total output drops: 0
  L2 Switched: ucast: 1251997827 pkt, 1179775309804 bytes - mcast: 410380869 pkt, 545148498927 bytes
  L3 in Switched: ucast: 1206517537 pkt, 309968572374 bytes - mcast: 15440864209 pkt, 21030454959390 bytes mcast
  L3 out Switched: ucast: 1927289505 pkt, 2069394447179 bytes mcast: 3185128542 pkt, 4342220954182 bytes
As you can see in red, it seems that the comand ignored multicast routed traffic.
Is it correct? is there a way to see the multicast routed traffic input and output rate?
Can some one of you show me a document with the theory about it?
Last one consideration, when I check VLAN graphics in Cacti or Nagios, they show me
complitely different result from "show interface vlan"... do you know why?
Thank you very much
Alex
Yogesh Ramdoss
Alessandro,
Let me try to help you with limited information provided.
When we issue "sh interface vlan X", the "5 minute input rate" and "5 minute output rate" provided
only the traffic sent to CPU (means, sent to control-plane for some reason).
Looks like, traffic received in vlan 10 is sent to CPU (at 2291 pkts/sec) for some reason. To know,
you need to SPAN RP Inband and analyze the traffic sent to CPU.
To know the total multicast traffic sent/received on a vlan, please look at the counters reproted for
L3-Switched traffic.
6506E-CS1-CORE#sh int vlan 10 <<== vlan 10
Vlan702 is up, line protocol is up <<== Vlan 702 ?!?!?! very confusing
Hope this helps.
Yogesh
Thank You very much Yogesh,
first of all I did a mistake with copy and paste so sorry for:
Now I have correct it.
I forgot to tell you that I'm using a Switch Cisco 6504 ios Version 12.2(33).
The reason I opened this post is because I noticed a difference between Cacti Graphic for Int Vlan 20
and Show interface vlan 20.
So I wondered why I didn't see traffic in output rate for Vlan20, I know that there is an host in Vlan20 that
is receiving 25megabit multicast traffic from Vlan10 (multicast routed in c6504 using pim).
How can I see this "output bit rate" in Vlan 20?
Ale
Alessandro,
Thanks for correcting the command results.
I do not think Cat6500 maintains a counter to report input/output rate of hardware-switched traffic per-vlan basis.
I guess, the SNMP application find the difference (in the number of multicast packets) between two successive pollings, and tell you the rate.
For e.g.,
At 1st polling ==> counter = 1000
At 2nd polling (done after 1 second) ==> counter = 2000
Then the rate = (2000-1000)/1 sec = 1000 pkts/sec
"show mls statistics mod X" provides you total number of L3-Switched traffic by specific module/EARL X, again not per-vlan basis.
- Yogesh
