R-PVST with other STP versions
james.hughes
Hi all.
I'm deploying a new NW and was planing to use R-PVST for my loop avoidence.
If i deploy this, and say, someone from the helpdesk plugs up another 3rd party switch that doesn't support PVST.. then loops the NW. Will i be safe?
lgijssel
Level 9
Level 9
Not likely, you will need at least two connections to create a loop. However, allowing others to attach switches to your network (without informing you) is never recommended.
To prevent and reduce this kind of risks, we have commands like bpdu guard:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
regards,
Leo
Thanks Leo.
That's what i thought. Cheers.
