RADIUS configuration scenario !?
mohammed hashim
hi,
most of the examples I saw regarding RADIUS configuration whether from Internet or books, are illustrated with VTY Telnet.
I am confused a bit here, is this the scope of RADIUS with Cisco IOS?
I was thinking about a scenario of
Host-1-----------------R1------------------RADIUS-Server
                            Host-2
is it possible to activate R1 interface faces Host-1 (if Host-1 wants to communicate with Host-2) through RADIUS authentication process?
if this is possible, can you please paste a sample of the configuration here?
thanks,
Francesco Molino
Radius can be used for network management access but also for the scenario you shared.
What you want to do is Nac. You need to configure the port to authenticate through radius server by using computer name, user/password, certificates or even mac address.
I hope this answer your question
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
khishtandar
hi
You can use  802.1x ( dot1x ) to do that .
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/122SX/configuration/guide/book/dot1x.html
best
pouya khishtandar
www.khishtandar.com
