Random Network Fluctuations
anujpal62
Dear Friends,
I am facing a problem in my network for Packet Drops in Network.My system is very simple I have three location where i have 3750 cisco switches installed and all the locations are connected Via Wimax Antenna.
From location one two second there's no packets drop but on Antenna 8.I'm getting packet Drops and because of that it always lose the communication with last location.And both Antenna's are connected via Same switch.There is not much load on any location and Main Server is located on first location with Antenna No.6.
I tried these things but faild please help.
* Changed Antenna Cable failed
* Changed the Antenna ports Failed
* Re-configured the Switch Failed
* Bandwidth tested at 20Mbp/s passed.
* Disabled the routing and EIGRP Failed
* Enabled Spanning tree fast faield no error came
I'm attaching the switch configuration of that Switch if anyone Can help me Please Please Please help..
Thanks in Advance.
Anuj Pal
0 Replies 0
