rapid-pvst+ and mst
Daviid Kumer
Hi, a question regarding the two STP variants MST and rapid-pvst+. In a network running rapid-pvst+, if we reach the limitation with rapid-pvst+ instances (128 per switch), can we just use MST concurrently with the new set of vlans? Or migration from one to the other will have to be done?
PVST or MST you can not run multi STP mode in same SW
so you must use MST if you have more than 128 VLAN run in SW.
