Rate-limit on Catalyst 6500
battanc
Two Catalyst 6509 in VSS, IOS 12.2.33
Is ther a way to limit the traffic bandwith on a specific VLAN?
reagards
Claudio
Reza Sharifi
Have a look at this doc for rate limiting examples an 6500 series:
An aggregate policer applies a rate-limiting  policy to all traffic in a VLAN or port that matches set classification  criteria (defined using an access control list [ACL]). For example, if  an aggregate policer defining a rate of 50 Mb were applied to a VLAN  containing 10 physical ports, then all traffic matching the  classification criteria (set by the ACL) entering those ports in that  VLAN would be subject to that policing rule and would not exceed 50 Mb.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
