rate limiting on an ethernet interface
mtp337
Hi Folks,
I need a little help, verification.  We have some 6509's with MSFC's running a bunch on virtual interfaces and we want to limit the bandwidth on one vlan/interface.  Here is my interface config:
interface Vlan110
description slow lane
ip address 10.1.110.2 255.255.255.0
no ip redirects
no ip unreachables
rate-limit input 8000 1500 2000 conform-action transmit exceed-action drop
rate-limit output 8000 1500 2000 conform-action transmit exceed-action drop
standby 110 ip 10.1.110.1
standby 110 priority 220
standby 110 preempt
When I test file downloads on this vlan I am still getting around 200 KB/s.  Yet I was expecting way less with the above config.  So I checked to see if
the interface is showing the limits:
hono-rhp-hb-gw01#sho interfaces vlan 110 rate-limit
Vlan110
  Input
    matches: all traffic
      params:  8000 bps, 1500 limit, 2000 extended limit
      conformed 0 packets, 0 bytes; action: transmit
      exceeded 0 packets, 0 bytes; action: drop
      last packet: 15253688ms ago, current burst: 0 bytes
      last cleared 00:31:58 ago, conformed 0 bps, exceeded 0 bps
  Output
      conformed 1069 packets, 126834 bytes; action: transmit
      last packet: 1060ms ago, current burst: 0 bytes
Yet I can download 200 meg files in less than 15 minutes...?
Giuseppe Larosa
Hello MTP337,
there are some aspects that need to be addressed:
exactly what type of supervisor and IOS image is on the C6509?
depending on the HW and IOS image the MSFC Vlan SVI can see only process switched packets and not packets that are switched by multilayer switching this would explain your results.
Another important point is the two endpoints used in the file transfer if they are in the same IP subnet the multilayer switch SVI is not involved in the process.
Also for multilayer switched packets you need to use different QoS tools that are applied to the PFC policy feature card that has its own QoS capabilities and features.
So it is likely you need to configure policers for PFC module in the supervisor at port level or at vlan level (L2 broadcast domain)
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1516886
Hope to help
Giuseppe
