Re: WS-C2960S-24TD-L
Navdeep Mann
Hi All,
Does anyone know if GLC-GE-100FX is supported on the WS-C2960S-24TD-L.  I don't see this switch listed under the compatibiilty matrix.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html#wp63326
But the datasheet for the 2960S says this:
"The Cisco Catalyst 2960-S with SFP+ does not support the GLC-FE-100BX, GLC-FE-100FX, or GLC-FE-100LX."
But it provides no reference for the GLC-GE-100FX
The easy answer is, no the 2960S-24TD doesn't support it, but I would really appreciate any clarification if possible.
Kind Regards,
BM
Bilal Nawaz
Hello BM, table 15 suggests that it is compatible with your switch with no comments with regards to incompatibility problems with your switch.
In the matrix, cant even find the switch model.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
GLC-GE-100FX=
100BASE-FX SFP module for Gigabit Ethernet ports, 1310-nm wavelength, 2 km over MMF
Not supported on the Cisco Catalyst 2960-8TC and Catalyst 2960G-8TC compact switches
This post here suggests that it works with the (TS) switch:
https://supportforums.cisco.com/thread/2080167
Cisco PDF state that this is an accessory for the 2960S
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_bulletin_c25-578924.pdf
Hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
