02-03-2017 06:40 AM - edited 03-08-2019 09:10 AM
Hi all,
Is it normal that "Readonly ROMMON initialized" message shows when Cisco 1921 is booting?
When I type "sh ver" it shows at the end of output that config-register is set to 0x2102.
Thanks in advance!
Solved! Go to Solution.
02-03-2017 09:42 PM
This is very normal.
02-03-2017 09:58 PM
That is normal during the boot sequence, if you enter to rommon mode you will see something like:
rommon 1 >
rommon 2 >
This link could be useful: http://www.smartpctricks.com/2015/01/cisco-router-boot-process-steps.html
02-03-2017 08:29 AM
HI!
can you pls share some more information like screen short .
thank you
CRaju
02-03-2017 10:28 AM
sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 12:31 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
R1 uptime is 4 hours, 0 minutes
System returned to ROM by reload at 14:07:46 UTC Fri Feb 3 2017
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO1921/K9
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data None None None
NtwkEss None None None
dir flash:
flash:c1900-universalk9-mz.SPA.154-3.M3.bin flash:ccpexp
flash:cpconfig-19xx.cfg flash:home.shtml
dir nvram:
Directory of nvram:/
253 -rw- 1223 <no date> startup-config
254 ---- 5 <no date> private-config
255 -rw- 1223 <no date> underlying-config
1 -rw- 2945 <no date> cwmp_inventory
4 ---- 396 <no date> persistent-data
5 -rw- 17 <no date> ecfm_ieee_mib
6 -rw- 559 <no date> IOS-Self-Sig#1.cer
02-03-2017 09:58 PM
rommon 1 >
rommon 2 >
02-03-2017 09:42 PM
