01-06-2015 03:14 AM - edited 03-07-2019 10:06 PM
Dear support,
We have the below device who made a restart, could you have a look in the flask info attached logs and et us what the reasons of this events?
l3rt-fra1-3#sh version
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 09-Oct-08 20:53 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
l3rt-fra1-3 uptime is 2 days, 7 hours, 36 minutes
System returned to ROM by bus error at PC 0x3240001C, address 0x42383582 at 04:26:49 UTC Sun Jan 4 2015
System restarted at 04:28:47 UTC Sun Jan 4 2015
System image file is "flash:c1841-advipservicesk9-mz.124-22.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 237568K/24576K bytes of memory.
Processor board ID FCZ125090HJ
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Thx / Jerome
01-06-2015 12:41 PM
The router is running an "T" train IOS. I'd recommend upgrading to the more stable "M" train IOS. Just make sure you check the release notes that the "M" train IOS you're upgrading to supports all the features your router has configured.
