redistribute ospf/ redistribute eigrp commands
sarahr202
Level 5
Level 5
Hi everybody.
How is everyone doing?
I was reading my book when I found  :
redistribute ospf 2 external 2
The book says  only ospf external routes of type 2 will be redistributed.
But when I tried to configure the above command on router, I was not able to configure it; there was no external or internal option available with redistribute ospf command.
Below is the output:
R2(config)#router rip
R2(config-router)#redistribute ospf 1 ?
  match      Redistribution of OSPF routes
  metric     Metric for redistributed routes
  route-map  Route map reference
  vrf        VPN Routing/Forwarding Instance
  <cr>
R2# show version
Cisco IOS Software, 2600 Software (C2691-ADVIPSERVICESK9-M), Version 12.4(15)T6,        RELEASE SOFTWARE (fc2)
Do we have such command for eigrp? For example  If i want to redistribute only external routes from eigrp into ospf,  do we have any command  such as  :
redistribute eigrp 1 external ?
I understand there is several ways to achieve to same goal however I am just curious if we could acheive the same goal using single redistribute eigrp  command without any route-map.
Thanks and have a great day
fb_webuser
Level 6
Level 6
R(config)#router rip
R(config-router)#version 2
R(config-router)#redistribute ospf 1 match external 1 ?
external Redistribute OSPF external routes
Posted by WebUser Sanjeewa Alahakone
fb_webuser
Level 6
Level 6
