Redistribute RIP into EIGRP network
shane.kearney
Hello everyone, I am building my own network at home and need some guidance
could you tell me how to redistribute RIP into EIGRP, the network at home I set up is using a the 10.10.10.0 255.255.255.0 IP and subnet and on the internet facing side of the router it uses RIP on network 192.168.1.0 255.255.255.0 the default gateway for the internet is 192.168.1.254, I am using NAT as well on the internet facing router to translate the 10.10.10.0 to 192.168.1.1. How can I redistribute the networks learned by RIP into the EIGRP network?
Any Thoughts???
2 Accepted Solutions
Richard Burts
Shane
Redistribution of RIP into EIGRP is not so difficult. The main thing to remember is that when you redistribute into a protocol you usually need to define a default metric. So redistribution of RIP into EIGRP might look something like this:
router eigrp 1
redistribute rip 10000 100 200 50 1500
This will redistribute the routes learned by RIP into EIGRP.
Rick
Rick
Shane
EIGRP can use 5 different metrics when it selects routes although by default bandwidth and delay are the only 2 used.
See attached link for more details -
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml#eigrpbasics
Jon
7 Replies 7
Richard Burts
Shane
router eigrp 1
Rick
Rick
cool I will try this thanks a mil.
Hi what does the 10000 100 200 50 1500 mean in the command??
Shane
Jon
Hello, what does the input 10000 100 200 50 1500 mean in the command
hello Shane,
all those parameters are there to provide the metric components to calculate the seed metric: the metric that EIGRP will associate to prefixes imported from RIP in this case.
EIGRP requires an explicit configuration of the seed metric you can do it in a separate line command with default-metric 10000 100 200 50 1500 or as Rick suggested in the redistribute command.
The difference is that using default-metric it can be used by multiple redistribute statements.
Without defining a seed metric no RIP prefix would be imported in EIGRP so it is a necessary step in redistributing into EIGRP.
Hope to help
Giuseppe
Shane
As Jon and Giuseppe have pointed out EIGRP needs 5 parameters as part of its route advertisement and calculation of metrics. For redistributed routes you typically need to supply those 5 parameters. If you are interested in the meaning of the parameters here they are:
10000 represents a figure for bandwidth
100 represents a figure for delay
200 represents a figure for reliability
50 represents a figure for load
1500 represents a figure for MTU.
It is not particularly important what specific values you use. I like to use figures that would be typical for a moderately attractive route. I have seen configs where people used a default that represented a very attractive route (very high bandwidth, very low delay, very high reliability, very low load) and that works also.
Rick
Rick
