Redistribute
zurita212001
Does anyone know of any repercussions of using the redistribute command in OSPF while having a default route configured?
royalblues
Level 10
Level 10
Default route will not get redistributed into OSPF unless you configure the default-originate command
SO if you want to redistribute routes into ospf except default, you can go ahead without configuring the above command
Narayan
JORGE RODRIGUEZ
Level 10
Level 10
Manuel, you did not specifed what you are trying to redistribute to but if you are refering to redistribute static routes I have not seen any repercussions when the device is participating in OSPF while you have defined gateway of last resort for that device by static means.
Jorge
Jorge Rodriguez
Narayan nailed it down !!
Jorge Rodriguez
zurita212001
Thank you all!
