Redistribution:
colmgrier
Level 4
Level 4
Looking at the correct way to redistribut EIGRP and Static routes into BGP. Please see below config.
ip route 86.43.157.69 255.255.255.255 2.153.42.29 254
router eigrp 90
passive-interface default
no passive-interface g0/0
no auto-summary
netork 2.153.83.0 0.0.0.255
netork 2.153.84.0 0.0.0.255
netork 2.153.85.0 0.0.0.255
netork 2.153.86.0 0.0.0.255
netork 2.153.87.0 0.0.0.255
router bgp 65500
no synchronization
bgp log-neighbor-changes
neighbor 86.43.157.37 remote-as 5466
no auto-summary
Please advise
C
What Jon suggests, indeed works. However, it dumps all of your statics and IGP routes into BGP, unless you filter what's being redistributed.
Another method is to use network statements within the BGP router configuration. This redistributes routes only already in the IP routing table that match the network statement. I.e., it might be little clearer what networks you want BGP to advertise.
(NB: I don't work with BGP that often, and I'm doing this from memory. Anyone that notices a mistake, please post a correction - thanks.)
e.g.
router bgp 65500
network 2.153.83.0 mask 255.255.255.0
network 2.153.84.0 mask 255.255.255.0
network 2.153.85.0 mask 255.255.255.0
network 2.153.86.0 mask 255.255.255.0
network 2.153.87.0 mask 255.255.255.0
network 86.43.157.69 mask 255.255.255.255
Often when working with BGP, we want to avoid route churn that might be caused by IGP routes coming and going. Also, we might want to only advertise a aggregate prefix for an address block. Either/both can be accomplished by using a BGP network statement that matches a static route which covers the addresses used by your IGP.
e.g.
ip route 2.153.83.0 255.255.255.0 null 0 200
ip route 2.153.84.0 255.255.252.0 null 0 200
router bgp 65500
network 2.153.84.0 mask 255.255.252.0
Jon Marshall
Colm
Simply add in the following 2 redistribute statements -
router bgp 65500
no synchronization
redistribute eigrp 90
redistribute static
no auto-summary
You can influence which routes are redistributed with route-maps and you can specifiy a metric for each redistribute statement but the above would be enough.
Jon
e.g.
router bgp 65500
e.g.
router bgp 65500
Accidental double post.
