redistribution
carl_townshend
Hi all, If I wanted to redistribute eigrp 100 into 200 and vice versa, Do I need to set any metrics ?
Jon Marshall
Hi Carl
You don't need to set metrics if you are redistributing between eigrp processes. You set metrics when the routing protocols you are redistributing between use different metrics eg RIP - hop count, OSPF - cost etc.
Jon
Thanks, So when I redistribute one in to the other, Will they both know about all routes in each others AS ?
Hi Carl
Yes they will if you redistribute both ways. You need to be careful when doing mutual redistribution between routing protocols.
Here's a link covering routing protocol redistribution. Have a look at example 3 in the Problems section which cover redistributing between EIGRP processes.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009487e.shtml
Jon
