04-19-2018 06:10 AM - edited 03-08-2019 02:43 PM
I have 2 switches 4500 switch one 4506-E with sup ws-x45-sup7L-E ios cat4500e-universal.SPA.03.10.01.E.152-6.E1
and switch 2 4507R+E with sup ws-x45-sup8-E
i need to configure redundancy between this switches .
Khaled
04-19-2018 01:38 PM
04-20-2018 03:16 PM
04-20-2018 05:39 PM
@khaledelsafy6 wrote:
I tried to configure VSS but when switch reload debug error tow supervisor not compatible
I thought you said you have two chassis with Sup8?
04-20-2018 03:25 PM
Since the Sups are different, you can't use VSS. You can, however, use HSRP or VRRP for redundancy.
04-20-2018 04:29 PM
04-20-2018 04:57 PM
Please post a sample config of a vlan from both switches that has HSRP enabled.
Also, post the output of "sh standby" from both switches.
04-21-2018 01:15 AM
04-21-2018 09:50 AM
Your configuration looks fine. I am not sure I understand when you say:
this output when i connected two switch direct with trunk port and switch number two no port active all ports in switch turned off
Can you explain the issue?
04-21-2018 09:53 AM
04-21-2018 10:01 AM
Are these core switches and do they connect to access switches? How do the access switches connect to the core? No ports should be turned off from either switch.
Can you post a diagram of your network?
04-21-2018 10:56 AM
I have 37 switches model 2960-x connected with two core via fiber cable all ports in Trunk mode
in core number two all ports disable when i turned it on both core come as active and network come doen
i need to active redundancy in this network
