Redundancy link setup help
terrencepayet
Level 5
Level 5
Hi guys,
Grateful if you could help me with the above subject. I want to setup redundancy between our sites via our ISP ADSL could without causing any loops, and i would like to know which technology will best suit our scenario. I've attached a network diagram for you to undertsand further. Take note that i want to use OSPF on all sites.
Thanks for your quick response.
Terence
Reza Sharifi
Hi Terence,
OSPF will work fine, but you don't have equal cost links to the same destination.  For example to get to 172.16.32.0/24 from site-A, OSPF will use the backup link and for 172.16.1.0 through 172.16.5.0/24 OSPF will would use the primary link, because these are the shortest paths to get to these detonations.
