Redundancy mode sso
vrtyler70
I have a new Model: WS-C3850-48P, SW Version: 03.07.00E, SW Image: cat3k_caa-universalk9. It is setup in the below settings but I am not running a pair of these switches. Are these switches setup in this manner by default? Can the redundancy be disabled if I am not going to use redundancy? What are the commands to disable redundancy?
switch 1 provision ws-c3850-48p
hw-switch switch 1 logging onboard message level 3
redundancy
 mode sso
Thanks in advance,
Vtyler
Reza Sharifi
No need to worry about that command since you only have one switch.  This command is enabled in all newer Cisco switch models.
Reza Sharifi
Thank you for your help and quick response!
