Redundancy on Cisco Switch 6509
sidcracker
Level 4
Level 4
This is just a quick question on understanding the redundancy features on the 6509 Switch. If we configure the switch using the following commands, would it configure high availability so that it auto syncs commands between the active and secondary 6500's
redundancy
main-cpu
  auto-sync running-config
mode sso
Do we still need to configure HSRP now that we have added this?
2 Accepted Solutions
   The following commands are used for a redundant supervisor engine on the chassis.
redundancy
main-cpu
mode sso
     If you have 2 chassises and want to do Active/Active or Active/Standby. You may think of HSRP , GLBP or VSS(If hardware supported).
   Ref HSRP:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/product_data_sheet0900aecd806ed759.html
   Ref VSS :
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html
HTH,
Toshi
Giuseppe Larosa
Hello Sidcracker,
HSRP can be still useful if you have two core / distribution switches but it is a different matter then SSO.
SSO builds a tight relationship between the two supervisors in a C6509 chassis. SSO messages are not exposed to outside world.
HSRP provides first hop redundancy: a VIP that can  be used by clients in a connected Vlan to reach the other IP subnets.
if you have only one C6509 box with no companion node (even of a different model) you don't need HSRP.
In old times in dual routing mode DRM an HSRP group encompassing both MSFCs on two boxes was used in some cases.
Now, we use SRM ( single routing mode) and only one MSFC speaks with outside world even with SSO enabled
Edit:
as noted by Toshi if you build a VSS pair you don't need HSRP or other FHRP like VRRP or GLBP on the connected client Vlans.
Hope to help
Giuseppe
redundancy
main-cpu
mode sso
   Ref HSRP:
   Ref VSS :
HTH,
Toshi
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As the others have already noted, using a virtual gateway protocol (HSRP, etc.) normally is only used when there's more than one chassis.  If you have a pair of 6500s that support VSS, then you wouldn't need a virtual gateway, just as you don't need it on a single chassis.
On the subject of SSO, which is a L2 redundancy features when there are two supervisors in the same 6500 chassis, if you're also routing on the 6500 chassis you may want to also enable NSF (if supported).
NSF:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/nsfsso.html
Nonstop Forwarding with Stateful Switchover on the Cisco Catalyst 6500
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd801c5cd7.html
Giuseppe Larosa
Hello Sidcracker,
Edit:
Hope to help
Giuseppe
Thanks Toshi and Giuseppe
