Redundent Problem for two ISP in cisco 891 router
Ibrahim Bhuiyan
I am using cisco 891 router for my office with two ISP. Both the ISP I am using for fail over or redundant. Two LAN separately is being used accordingly with two ISP. But the problem is when one ISP connection has goes down then another ISP does not worked. If I disconnect the cable of the down cable from router then another ISP works fine. I can't understand the problem. I already attached the configuration file below. Please suggest what will be solution?
5 Replies 5
M. G.
when you say "the first ISP goes down" what do you mean by that? Is it the physical link or ISP network? If it is the latter, then the problem that you have is that ISP router is still active and the route on your 891 is sending traffic there. When you physically disconnect that interface goes down and the router reroutes the traffic.
Use policy based routing with IP SLA for tracking. Track 8.8.8.8 or similar, when it is not reachable, configure the router to reroute to the active interface.
Check the below example for more details
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200785-ISP-Failover-with-default-routes-using-I.html
regards,
mg
Thank you M.G.
the first ISP goes down means ISP link down. But I use two LAN for two ISP. If one is down then another will work. but after one down another ISP connection does not work.
Did you check the configuration file?
Hello
can you post tha configuration of the rtr
res
paul
Kind Regards
Paul
Please check the attachment.
I have made some changes to your configuration (relevant parts in bold). See if you can implement this and get it to work: The WAN IP addresses are (obviously) arbitrary, replace those with yours.
boot-start-marker
boot-end-marker
enable secret 5 $1$04u5$RNzJZLXMil1tLt2iJeR4B0
aaa new-model
aaa session-id common
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.10.1
ip dhcp pool pool1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server x.x.x.x 8.8.8.8
ip dhcp pool pool2
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip name-server 8.8.8.8
ip cef
no ipv6 cef
track 1 ip sla 1 reachability
license udi pid C881G-U-K9 sn FGL184923HC
controller Cellular 0
ip ssh version 1
interface FastEthernet0
switchport trunk native vlan 2
switchport trunk allowed vlan 1,2,20,30,1002-1005
switchport mode trunk
no ip address
interface FastEthernet1
switchport access vlan 20
no ip address
spanning-tree portfast
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 100
no ip address
interface FastEthernet4
description ISP1
ip address 1.1.1.1 255.255.255.240
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Cellular0
no ip address
encapsulation ppp
interface Vlan1
no ip address
interface Vlan2
ip address 172.16.1.1 255.255.255.0
interface Vlan20
description lan side for WLAN1
ip nat inside
interface Vlan30
description lan side for WLAN2
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan100
description vlan for ISP2
ip address 2.2.2.1 255.255.255.252
ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT_ISP1 interface FastEthernet4 overload
ip nat inside source route-map NAT_ISP2 interface Vlan100 overload
ip route 0.0.0.0 0.0.0.0 1.1.1.2 track 1
ip route 0.0.0.0 0.0.0.0 2.2.2.2 10
ip sla 1
icmp-echo 1.1.1.2 source-ip 1.1.1.1
ip sla schedule 1 life forever start-time now
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
route-map NAT_ISP1 permit 10
match ip address 101
match interface FastEthernet4
route-map NAT_ISP2 permit 10
match interface Vlan100
event manager applet CLEAR_NAT
event track 1 state any
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat trans forced"
control-plane
line con 0
no modem enable
line aux 0
line 3
no exec
line vty 0 4
exec-timeout 60 0
password 7 107D100A0B12065A5E570A
transport input all
line vty 5 15
transport input all
end
