Regarding "authentication violation shutdown" cmd of 12.2(53)SE2
ilmin
Dear Experts,
I have a question about an authentication violation issue on Cat2960.
HW/SW:
- WS-C2960G-8TC-L
- c2960-lanbasek9-mz.122-53.SE2.bin
Issue:
According to the following document, by default authentication violation shutdown mode is enabled.
Also, if that was configured "shutdown" as a default, the port should be become err-disable when a new device connects to a port.
However, a port does not become "errdisable" even if it was connected to non-allowed device.
It become "errdisable" in "dot1x violation-mode shutdown" of IOS12.2(46)SE.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2960/software/release/12.2_53_se/command/reference/cli1.html#wp11888832
Use the authentication violation interface configuration command to configure the violation modes that occur when a new device connects to a port or when a new device connects to a port after the maximum number of devices are connected to that port.
By default authentication violation shutdown mode is enabled.
My question is following.
Why does not it become "errdisable" in 12.2(53)SE2? Is this an expected behavior on 12.2(53)SE2?
To configure an IEEE 802.1x-enabled port as error disabled and to shut down when a new device connects it, do we still need to configure the port?
Below is the configuration.
'authentication violation shutdown' cmd is invisible because of default.
aaa new-model
aaa authentication login default line
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
dot1x system-auth-control
errdisable detect cause security-violation shutdown vlan
errdisable recovery cause security-violation
interface GigabitEthernet0/1
description 1x Access Port
switchport mode access
switchport nonegotiate
authentication port-control auto
authentication periodic
authentication timer reauthenticate 43200
mab eap
no snmp trap link-status
dot1x pae authenticator
dot1x timeout tx-period 1
no cdp enable
spanning-tree portfast
If you have any questions regarding the content, please let me know.
Thank you very much for you help!
Ilhong.
0 Replies 0
