Registry value issue
Mohammed Saleem
Hi Am Facing the below issue.
Unable to change the registry value from 0x2922 to 0x2102
I given the below command.
config#no service password-recovery
config#Configuration register is 0x2102
After this I checked sh ver, but its showing
Configuration register is 0x2922 (will be 0x2B22 at next reload)
Am not able to change the value. Kindly help. its very urgent as this is a live switch.
10 Replies 10
Reza Sharifi
Can you try changing:
to
and than try changing the registry to 0x2102?
Sorry Reza,
Its give below output
#conf t
(config)#service password-recovery
(config)#config-register 0x2012
(config)#do sh ver
Configuration register is 0x2922 (will be 0x2832 at next reload)
Can you post the output of "show boot" after changing it to 0x2102?
It maybe a bug in the version you are running?
What ver are you running?
Hi Please find below and suggest
#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500es8-UNIVERSALK9NPE-M), Version 03.06.03.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 26-Aug-15 21:30 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG5
MT10B-HR-C4510-SPARE-CHASIS uptime is 1 day, 4 hours, 3 minutes
Uptime for this control processor is 1 day, 4 hours, 5 minutes
System returned to ROM by reload
System restarted at 19:52:22 IST Mon May 30 2016
System image file is "bootflash:cat4500es8-universalk9npe.SPA.03.06.03.E.152-2.E3.bin"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
    License Level: lanbase   Type: Default. No valid license found.
    Next reboot license Level: lanbase
cisco WS-C4510R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS1933Q1XM
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from Reload
2 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
#sh bootflash:
-#- --length-- ---------date/time--------- path
  1  199187968 Nov 04 2015 09:23:38.0000000000 +00:00 cat4500es8-universalk9npe.SPA.03.06.03.E.152-2.E3.bin
1411776512 bytes available (202014720 bytes used)
Please, show these
show bootvar
4500 is switch, in more cases for switch more important bootvar configuration, than config register which shown in show ver output.
HI Alexe,
Below the output.
#sh bootvar
BOOT variable = bootflash:cat4500es8-universalk9npe.SPA.03.06.03.E.152-2.E3.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
Not sure if this is related or not but you have an issue with you license:
What is the license you purchased with this sup?
also post the output of "sh boot" and not sh bootflash:
Yes, you need to fix the license issue first and than the registry.
I really do that one first. Thanks a lot . will get back soon sir.
Hi Reza,
Said command is not running.
#sh boot
% Ambiguous command:  "sh boot"
