Regular Expression for Cat6500
sivaprakasam81
Level 5
Level 5
Hi All,
What is regular expression?
Where do i find the info on regular expression for cat 6500 Switch?
Thank you,
lamav
Level 11
Level 11
A regular expression, otherwise known as regexp, are symbols derived from programming languages that allow you to filter prefixes in BGP advertisements based on Autonomous System paths.
The regular expressions search strings of text for specific target characters. In BGP, they are used to configure as-path access lists.
Example:
ip as-path access-list 10 permit ^$
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml#asregexp
http://www.regular-expressions.info/
Victor
Thank you victor.
will work around this sites to get more info.
Need to get logging info (syslog info) into the server. Do you have any specific document for this?
Thank you again!!!
Hi:
Not sure what you mean.
You want information on how to configure a Cisco device to send system information to a syslog server? Or are you looking for information on how to configure the server itself?
Victor
