reload FWSM in VSS Mode
Mhon Baul
Hi All,
  I would like to reload my FWSM configured in failover mode, the switch is in VSS mode. Is the command "hw-module module # reset" will reload the two pair FWSM or only the active one? thanks in advance!
cheers!
reymon
Hi Reymon,
Yes, that should do it
Reza
Reza Sharifi
For VSS, add switch 1 to the command if you want to reset the module in switch 1
hw-module switch 1 module 6 ?
Reza
Hi Reza,
  Many thanks on the quick response. Sorry I forgot to mention on my  first post that I want to reload  the two fwsm in the VSS mode.
  Is the  "hw-module  module 6 reset" the right command to do this?
Thanks again,
cheers!
reymon
Hi Reymon,
Reza
