Remote RSPAN VLAN Config
roxysbrian
I'm trying to configure a RSPAN on remote VLAN 902 to monitor VLAN 101 but I'm not sure how to go about doing this. I have the remote VLAN configured in my switch but not sure how to tell it to only pull the traffic from VLAN 101.
Here is parts of my current config:
sh run
monitor session 2 destination interface Gi7/40
monitor session 2 source remote vlan 902
<BR>
sh vlan
902  RSPAN_Voice              active
<BR>
sh monitor session 2
Session 2
Type              : Remote Destination Session
Source RSPAN VLAN : 902
Destination Ports : Gi7/40
    Encapsulation : Native
          Ingress : Disabled
         Learning : Disabled
<BR>
<BR>
Brian
roxysbrian
After doing some more research I answered my question. Here is what I found:
There are different commands that need to be run on the source switch(es) and the destination switch.
Source switch:
monitor session 2 source vlan 101
monitor session 2 destination remote vlan 902
Destination switch:
monitor session 2 destination int gi7/40
The commands for the source switch(es) must be put on every switch that will have source data on VLAN 101.
Hope this helps someone.
NOTE: Above info was related to my situation. Your situation may be different from mine and you may have to adapt accordingly.
