03-25-2007 11:13 PM - edited 03-05-2019 03:05 PM
is there any command through which dynamic routes can be removed if after expiry of hold timer that particular route is not removed from routing table?..how to configure such command?...help me out as i am in need of it
03-25-2007 11:44 PM
Hi Friend,
You can try the command
"clear ip route {network [mask] | *}
You can have a look at the link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_r/1rprt2/1ripadr.htm#1017827
Ankur
*Pls rate all helpfull post
Log in to Community
