Removal of ip route command
mahesh18
Level 6
Level 6
         Hi all,
Need to confirm Network config below
We  have client where they are using layer 3 switch with no ip routing enabled.
It has default-gateway  command configured.
Need to confirm that ip route command is used for layer 3 switch only and it switch is used as layer 2 only it is ok to be removed?
Mahesh
2 Accepted Solutions
Reza Sharifi
Hi Mahesh,
Yes, if the switch is layer-2 only, you don't need the IP routing command, you just need the ip default-gateway command.
acampbell
Mahesh,
Running default-gateway is OK.
Example
no ip routing
interface vlan 555
description *** Management Vlan **
ip address 10.5.5.5 255.255.255.0
no shut
ip default-gateway 10.5.5.254
So basically the ip address 10.5.5.5 is just for managing the swtch.
The switch is only carrying out layer 2 functions
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Reza Sharifi
Hi Mahesh,
Hi Reza,
Many thanks again
Mahesh
acampbell
Mahesh,
Example
no ip routing
interface vlan 555
no shut
Alex.
Hi Alex,
Thanks for additional info
Mahesh
