Replace C3750-24p Master switch with C3750-48P switch
john_hunt
I need to replace a WS-C3750-24P switch (currently the master switch) in a stack of 4 switches with a 48 port model (WS-C3750-48P). I plan to shut down the master switch 1, remove the StackWise cables, cable up the replacement 48P 3750, and power it on. The new 48P switch needs to become the master.
Will this apply a default configuration to the 48P switch as the models are different, and if so, should I modify the provisioned switch in the running config to "switch 2 provision ws-c3750-48p" after removing switch 1 and before powering up the 48P? If not, is there a recommended procedure to follow?
The current layout is as follows:
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C3750-24P       12.2(55)SE8           C3750-IPBASEK9-M
     2 52    WS-C3750-48P       12.2(55)SE8           C3750-IPBASEK9-M
     3 52    WS-C3750-48P       12.2(55)SE8           C3750-IPBASEK9-M
     4 52    WS-C3750-48P       12.2(55)SE8           C3750-IPBASEK9-M
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0013.c351.7400     3      0       Ready
 2       Member 001f.9d96.d580     2      0       Ready
 3       Member 0013.c332.2680     1      0       Ready
 4       Member 0013.c332.3c00     1      0       Ready
The running-config is set as:
switch 1 provision ws-c3750-24p
switch 3 provision ws-c3750-48p
switch 4 provision ws-c3750-48p
John
2 Accepted Solutions
Leo Laohoo
1.  Save the configuration;
2.  Power down Switch 1;
3.  Remove the stacking cables from Switch 1;
4.  In configuration mode, do the following
config t
no switch 1 provision ws-c3750-24p
switch 1 provision ws-c3750-48p
end
wr
5.  Install the new switch and cable up the stacking cable;
6.  Power up the new switch;
7.  Configure the ports; and
8.  Once the new switch has joined the stack, configure the stack priority
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What Leo describes is great, but wanted to note, your replacement switch will not be the active stack master.
3750 stack elections only happen when they need to, i.e. there is need to elect a new stack master.
There are several ways to get your replacement switch to become the new stack master.  One would be to power cycle the active stack master (should be stack member 2) after the replacement switch is fully on-line (and provisioned with the highest priority, as noted by Leo).
Leo Laohoo
config t
end
wr
Disclaimer
Posting
