replace HP ProCurve with Cisco
sungajjar
What is recommended to replace below HP ProCurve Switches with Cisco?
stacked HP ProCurve Switch 4108gl (with 4 x 24 port 10/100 modules, 1 x 6 port 1000T module ,4 x 1000 Fibre)
& HP ProCurve Switch 2810-24G - need equivalent Cisco 3750
Looking for equivalent 3560 switches for below HP switches:
HP ProCurve Switch 2524
HP ProCurve Switch 2626
HP ProCurve Switch 408
HP ProCurve Switch 1800-8G
Joseph W. Doherty
"What is recommended to replace below HP ProCurve Switches with Cisco?"
You're routing on the 4108gl? If not, 3750 might not be the best option.
A 3750 stack of two 3750V2-48TSs and a 3750G-24TS-1U might meet your requirement. This would provide 96 10/100 ports, 24 10/100/1000 ports and 12 SFP ports.
"Looking for equivalent 3560 switches for below HP switches: "
These need to be routing capable? If so, more or less match your required port density and port bandwidths. 3560 list can be seen here: http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_models_comparison.html
If routing not needed, you might choose from: http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_models_comparison.html
Leo Laohoo
The question I am interested in is do you want a Layer 2 or a Layer 3 switch?
The only Layer 2/3 stackable switch is the 3750 while for Layer 2 alone the 2755 is a candidate.
Cisco Catalyst 2975 Switch with LAN Base Software
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10081/data_sheet_c78-502660.html
One of the key features:
48 10/100/1000 PoE ports and 4 Small Form-Factor Pluggable (SFP) uplinks
High-speed stacking for up to nine switches and support for cross-stack EtherChannel
Unified stack management to simplify management of the network access layer
Hope this helps.
