Replace Network Module on 3750x
id0982360
Dear,
I'd need to replace a network module (C3KX-NM-1G) on a stack of 7x C3750-switches.
The goal is to replace it by C3KX-NM-10G module.
The switch is of type 3750x-24T-S.
Question; are these modules Hot-swappeble ?
Or do I have to power down the switch in the stack ?
Julio E. Moisa
Yes the modules are hot swappable. Although they are hot swappable Cisco recommends execute the procedure with power off.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/net_mod_note.html
Please rate the comment, thanks
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
