Replacing a stack switch cable
Larocha
Visitor
Hello Cisco Community,
I have a stack with three switches 3850, I replaced a faulty stack cable and switches 2 and 3 restarted, everything is working with no problems. My question is, did I did something wrong? or is it normal that the switches restarted?
Thank you for your help,
Regards.
Mark Elsen
 - Provided you have a redundant-ring left ; they should not restart.
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you, That is what I thought.
Martin L
Up to cretin version of XE software, they will reboot; after version x , the fix was applied and switches do not reboot. check doc for version x number and spec
