Replacing Distribution Switch
What is the important configuration need to backup or need to be copy in the distribution switch? because we have plan to replace the DSW but in still in the same model 3750.
3 Accepted Solutions
Leo Laohoo
Copy the entire lot.
johnlloyd_13
Level 9
Level 9
hi,
are they stacked?
you'll basically need to migrate the config from the show run output, i.e. VTP, VLANs, STP, L3 and L2 port config, L2/L3 etherchannel (if used), L2 or L3 default GW.
Currently only DSW is working because the other one is faulty , so now we need to replace stack DSW. Please advise
Leo Laohoo
johnlloyd_13
Level 9
Level 9
hi,
are they stacked?
