12-05-2012 12:54 AM - edited 03-07-2019 10:24 AM
my two HO router is connected in MPLS cloud behind HO1 router web server 1 is connected. i want from MPLS cloud any branch (A, B or C) when want to go to WEB SERVER-1. HO-1 router should be replicate that tropic to WEB SERVER-2 which is behind connected to HO-2 router.
1) what acl should be configure on HO-1
2) It need to create Route-Map
3) Or static NAT
Suhas
12-05-2012 01:01 AM
let me try to understand: you want traffic going to webserver1 and in case of failure go to webserver2 ? or you want some traffic going to webserver1 and other going to webserver 2 for load balancing ?
Regards.
Alain
12-05-2012 02:56 AM
No i do not want any load balancing, i want when any branch from mpls cloud access WEB SERVER-1 ip add HO-1 router should be redirect this traffic which has come for WEB SERVER-1 to HO-2 Router and that can access WEB SERVER-2.
which branch from MPLS cloud is accessing WEB SERVER1 should not know that we are accessing HO-2 WEB SERVER.
Suhas
